My W115 when started up will sit and idle but it doesn't sound right and the battery light is lit up on the dash. If you gently try to give it some throttle it stalls.
Today I was a little bit more brutal without the old bugger and gave it some throttle only to find that it would pop loudly from the air intake area.
I'm not 100% sure but if the engine is being starved or air would it cause the car to stall? What could the popping be?
Once the car has warmed up after about 10 mins the battery light goes out and the car drives fine.
Is it worth me replacing the air filter or even possibly removing the original air filter + housing all together and fitting something like this
http://www.needforspeed.co.uk/pages/sbv_pl.asp?Vehicle=MB__802&PartType=AFK01
Any advice appriciated as usual.
