Hi, I'm trying to get my Dad's 230E 1982 ready for sale. It's a 1 owner car with 23,000 miles. It's been unused for almost 10 years.
I've fully serviced it (all fluids, brakes etc) and it now starts easily. It's a little lumpy when cold but I've put that down to the auxilary air valve being a bit lethargic.
After a few minutes it's driveable. The problem is after 20 minutes or so driving it then misfires very badly if I give it anything more than a gentle throttle.
Here's a list of everything that has been done:
Ignition:
Replaced sparkplugs, ht leads, distributor cap. Cleaned rotor arm.
Verified coil and ignition module voltages and resistance values as best as I can with data from the manual.
Idle mixture was ok for MOT and sparkplug colour suggests mixture is correct.
Reset valve clearances.
Compression test cylinders - all 180 - 185 psi
Fuelling:
Drained fuel tank, verified fuel tank strainer was clean, replaced fuel pump & fuel filter, added new ethanol free fuel and injector cleaner.
Replaced fuel injectors.
Replaced fuel distributor inlet filter, inspected the fuel distributor injector outlets and other ports all clean, verified plunger not sticking.
Cleaned warm up regulator inlet filter.
Checked operation of cold start injector, WUR and Auxillary valve bi-metal strips - all ok.
Veried fuel accumulator holds pressure and injectors and cold start valve are not leaking.
Verified that fuel delivered to all injectors when pump engaged and venturi plate depressed.
Check fuel pump flow rate
Check k-jet fuel pressures
I took it to a mercedes specilist who verified that the fuel pump delivery rate was correct and the kjet control and system pressures were ok but he didnt drive the car with the gauge connected so didnt observe whether fuel pressure was being lost. The fuel pump is a little noisey (about the same as the one it replaced) and he wanted to change it but as it had already been changed and the delivery rate was ok I declined.
He did also suggest soaking the fuel distributor in meths but I didnt think that was a good idea for the internal orings. Besides all the ports look perfectly clear and the fuel seems to deliver equally to all ports.
So I'm now a bit stumped. I'm tempted to get a gauge and test the fuel pressures myself. I contacted KMI but apparently they dont test WUR and fuel distributors, they just rebuild them. Obviously I'm reluctant to fork out almost £1k to get these rebuilt without verifiying they are faulty first.
So if anybody can help with any of the following it would be appreciated:
1. Does a violent jerking misfire on acceleration sound like fuel starvation or an ignition problem?
2. What might cause a loss of fuel pressure only when hot?
3. Is there anyone in the UK who tests Kjet fuel distributors?
Ignition:
Fuelling:
