CharlesJones
- Aug 10, 2007
- 1982 Mercedes W123 230E Saloon, and a 1984 Porsche 911 Coupe.
Hi everyone,
I have a 1982 230E which needs a new water pump, but I can't for the life of me get the water pump pulley off. I have removed the fan and what you see in the photos is what I am left with. It says in the workshop manual that the pulley should now just pull off by hand, leaving the magnet body of the electro-magnetic clutch mechanism behind. However I can't budge it, despite hitting it with a rubber mallet and tugging it with all my might. I even tried levering it off with the handle of a carefully positioned wrench, but all I succeeded in doing was bend the rim of the pulley so I stopped that.
It says in the workshop manual that if the pulley can not be removed by hand I should remove the central "assembly bolt" and replace it with a longer bolt which can then be tightened to force the pulley off against the magnetic body. I have tried this, but I can't get the assembly bolt out - its like its welded in! I can't get a socket very far over the hex part of the bolt so I have only succeeded in rounding it. Then I tried gripping it tightly with mole grips but and that time I just damaged the thread.
Do any of you have any other ideas of anything else I might try? What about applying heat with a blow torch? If so, which bit should I heat? Any tips about that?
Also, it says in the manual that I should remove the radiator to get better access. I haven't done this since I was worried about disconnecting the pipes to the oil cooler for the automatic transmission. However, if this will genuinely help to get the blasted pulley off then I just have to do this I guess. Does anyone know if removing the radiator would genuinely help get purchase on the pulley? I only want to do this as a last resort.
Many thanks for your help. I have attached some pictures of the pulley so as to illustrate which variety it is. This is driving me mad - I've spent three days of hammering, tugging and pulling at it, and a lot of staring at it, but it just won't budge! Any advice or tips would be VERY gratefully received!
Best regards,
Charles
Best regards,
Charles
