seeing as there may be a problem* with my starter motor on the 280CE I got hold off another one (allegedly recon) off the internets for a good price.
So, today, as for once it's dry I thought I'd have a go at fitting it. And got precisely nowhere. Has anyone ever succeeded in removing the starter from a 280CE auto? I did actually succeed in modifying a 10mm allen key to fit the top bolt and I even got the modified key *in* the socket, however the bolt is sufficiently tight that the key broke rather than loosening it. There is no way I can see of accessing that bolt with any normal tool, short of cutting an access hole in the bulkhead, which is kind of drastic - however the other option, which would seem to be "remove the engine and gearbox" doesn't look attractive either.
any thoughts would be welcome
* intermittently it turns over very slowly, as in so slowly that the engine doesn't start. Generally, so far, it then behaves and works properly. However being an auto, one day it will stop working and then the car won't go, seeing as I assume it isn't the clever kind of auto that can be tow-started - the only 2 of those I know of are the AP unit fitted to the minis and the BW35 as fitted to older rovers, fords and such which had a rear oil pump driven from the output shaft.
