damiangt3
Hello,
I've recently taken ownership of a UK 1992 230E and have a few questions regarding the duty cycle reading I'm getting.
So far I've checked the plugs and they are fine, a little carbon but overall brownish-white and in good condition. I've changed plug leads for new Bosch ones and the replaced thermostat. The distributor and rotor arm are new, I've also replaced the Intake Air Temperature sensor as it was literally in pieces and dirty as hell. The OVP has been replaced too.
I've been running 98-99RON fuel with injector cleaner in it for the last 3 tankfuls and I've got the EZL-KAT set to S. I've averaging 350 miles until the fuel warning light comes on.
I have quite poor warm and cold starting, takes 3 attempts before it fires and does require a little accelerator before firing. Idling at hot, warm or cold is steady.
Right, on to the duty cycle. checked the conditions whilst cold and ignition on where the duty cycle reads 70% and 20% when moving the accelerator. On starting the car and running whilst cold it reads around the 50% mark. All this seems to be correct from what I have read, however when the car reaches operating temperature it still reads 50% and this does fluctuate too much on throttle. I was expecting to at least have to adjust the mixture a little, what worries me is that the car possibly never starts in open-loop hence the poor starting. Is this a sign of a faulty Coolant Temp. Sensor? Is the mixture setting only 'enabled' on open loop?
Any advice would be welcomed!
