hi my dad has owned a 1991 300te 24v esate for a short while but it hasnt been used much due to a fault occuring, when the car was purchased it ran fine no missing spluttering etc but since has started playing up,
when the car is started from cold it runs perfectly right up untill it reaches around 82/83 degrees then it splutters and cuts out. when you attempt to restart it, it will razzle over then splutter then not start, you can keep doing this and the car refuses to restart.
if you leave the car for a few hours it will restart fine and the same problem occurs.
if you force the car and manage to keep the revs right up once the temp has exceeded around 85 degrees and is up to norm working temp it will drive and run perfectly.
rotor arm, leads.plugs, dizzy cap, icv, along with fuel supply have all been checked with no visible faults, along with air filter etc
from what i can find out something is telling the ecu, to either over fuel the car or to cut the fuel supply at the temp (no excess fuel smell and no backfire etc when trying to restart) or the ecu is not recieving the correct data back,
any idea what sensor could be at fault and any images of its location would be really helpfull?
