W124 500TE - Lets do this!
Sadly Chris did not make it over the weekend but he did make a little progress last night.
The 500 quarter panels were cut off last week:
The wagon arch has been slowly trimmed back to the point where Chris could make a nice clean join to both the inner arch and the actual quarter panel.
When it comes to welding, it has to be done very carefully to avoid distorting the panel.
This is de ja vous from when we did the SEC widebody back in 2008. Same process, if not a little trickier as we have to go inside the door shut this time.
Unfortunately I discovered that the wiring harness that supplies the headlamp, horn etc has a different connection under the fuse box. The 500 has a larger plug with more connections. I need to come back to this to figure out what the extra four wires are for. So im still not done with wiring
Small spotlights in the front spoiler under the bonnet? Headlight wash wipe?
http://www.autolib.diakom.ru/CAR/Mercedes-Benz/1995/E320/SYSTEM WIRING DIAGRAMS/5460.pdf
or something else here?
Im a firestarter, a twisted firestarter… that’s how I feel, like taking a match to it all.
All was going so well. I had the engine heads on last night, ready to time up the chain etc.
After the above last nights update, a message was soon posted which changed my mood from mildly cheerful to one requiring the use of a straight jacket.
It had not occurred to me at all, but a member on the 500E forum noticed that the insides of the piston bores were not finished correctly for an “alusil” block.
The finish that the first engine builder guys did for me is a traditional hone which leaves a cross hatch pattern as you can see in the above pictures.
Apparently these blocks require a special three of four stage honing process which ends with a final hone using silicon paste which totally smooths the inside surface of the cylinder walls. This, it seems, is imperative unless I want to scrap my engine.
Thanks to the eagle eyed members who spotted this error.
After I read this post, I quickly started researching. I found many (two) old videos, made in the days of Beta Max cassette tapes, showing the process.
Ze German guy explains it best. I didn’t understand a word but the video says it all.
This process is specific to Alusil bores and narrows it down considerably to M117, M119 and some others that used these blocks, if we confine to Mercedes. Porsche and some others also used these.
As these blocks are pretty much indestructible, we have never had to rebuild bottom end on one before and not many other garages have that I have spoken to.
After all if you have a problem with bottom end on M119, you would probably just buy a second hand engine for next to nothing. Unless it’s a 500E and the blocks aren’t readily available.
It became clear that No1 engine builder was not aware of this required process. It was done now but luckily I haven’t started the engine and no damage has been done. Decisions to be made.
I then experienced various psychological states.
Around 11pm last night I was in denial. There must be a reason why they honed it this way. Maybe it will be fine. How much difference can running some special grease through the bores for a minute actually make?
I woke up feeling regret. Dad always told me that I shouldn’t touch things that weren’t broken. It’s my way to keep going until I’m satisfied. This block should probably have been left as it was. Possibly just new piston rings would have sufficed.
The sandy finish inside the bores before we started the work, is exactly what we are now looking for.
Then came acceptance.
My plan to have the engine built today and possibly in the car over the weekend was out of the window. It dawned on me that I would never be happy to just suck it and see. Even if the engine started up and didn’t smoke, it would bug me every time I saw the car.
This morning I spoke to all of the local engine builders. Out of five calls, only three knew what I was talking about. Only one has ever had the equipment to do it and no longer has it now due to lack of demand.
I spoke to other engine builders further out. After several calls only one company I found still does this work. Not local.
So at 10am this morning I undid all of last night’s work. Removed heads and stripped the block down again. So very frustrating.
Got it loaded and is currently being driven to Engine builder No 3.
My biggest worry now is that this builder will decide there is not enough cylinder left to hone and it needs liners. I don’t want to go down this road if possible.
They say they are very busy and could take up to two weeks to turn around.
Ah well, I guess I now have time to sort out that headlamp wiring.
Thanks again to those who spotted the problem and posted. Very much appreciated. Now where is that voodoo doll.
I can see this bugging you every time you turn the key.
You made the right decision. If you are going to all this hassle of a complete engine re-build, best to be happy with it.
According to Brian Ellis in the December issue of the Gazette the inhouse magazine of the Official Mercedes-Benz Club only 29 cars
[25 500E's and 4 E500's]were officially imported as UK spec cars and sold by the UK dealer network during their production run.
Maybe something to do with the £60,000 price tag in 1991 compared to a W124 300 TE-24 Estate [ closest conversion car analogue] which would come in around £35,000!
Chris is doing some more today.
He is spot welding slowly and then griding back. Spott welding some more and then grinding back… Repeat until the join is totally smooth.
He is not risking one continuous weld as the heat will distort the panel.
I stripped the intake manifold down to its component parts and replaced all gaskets, seals etc. Gave it a clean out too.
Replaced all injector seals, vacuum hoses and rubber breather hoses. Its much easier to do whilst its out.
Absolutely brilliant and funny thread. No sense of stuffiness or look at me “I’m rich and brilliant “[emoji1303]
Sent from my iPhone using Tapatalk Pro
Thats because I spent all my money at the Mercedes parts counter ;)
Likewise. Spent 3k in 9 months keeping the CLS on the road. Just one stupid issue after another. Sold it a few weeks ago. Now a BMW tosser
You've done good by listening to people on the Alusil honing. You have to bring the silicon up with these engine, crosshatching won't be enough to bed the rings in. I've learned the hard way. Not that there was anyone around to advise at the time.
Is the company you're using based in Kent? There's a well known Alusil specialist down there. Not the only one, just one of the few. Hampshire is another place to use.
Nice project, thanks for sharing.
here's another video on alusil finishing- in english this time.
this is probably the finishing compound altho others may be available
AN-30 : Silicon Compound for Honing
see instructions AN-30 PDF here
I find it amazing that this process lasts.. One would think the silicon would be worn away the moment the engine is run leaving the bare aluminium...
Alex - I couldnt find many places at all. They are in the London area, will post their name once the job is done.
Figure%202-resized.jpg;width=560;quality=90
Figure 2—An ideally honed surface imaged by SEM (scanning electron microscope) shows smooth, round-edge silicon crystals (dark areas) protruding above the aluminum base.
Here's a good article on the metallurgy. Crucial to the properties of the alloy is the hyper concentration of the silicon allowing solid crystals of silicon to precipitate out of the melt rather than be chemically combined as an alloy.
New Honing Options For Hypereutectic Aluminum Cylinder Bores
