Hello all, i'm new to the world of mercedes and very pleased with my E200 It has a few small things that need to be done to get it spot on, one of which is there is a light ticking from the engine. I've done a search and found out its most likely the sepentine belt/poly belt/ribbed belt (what is it correct name?) and tensioner. One post mentioned the tensioner bearing is a Mercedes only part! is this because it not worth messing about with a pattern part or is it just the bearings on their own and the tensionr can be fixed. Does anyone know how much mercedes charge for a belt and tensioner? they're £9.50 and £17.95 respectively from GSF.
The other thing that needs doing is some of the dash illumination bulbs have gone. Most are 12v 1.2w bulbs but the ones that light up the little arrow on the fan and direction knobs have a grey plastic base. I changed these for the all glass 286 but the knobs are getting hot and appear a bit bright at night. Mercedes would only sell me the 286 bulbs but I must need a lower power bulb for the knobs?.
