I thought I'd fixed that! We replaced the rear diff speed sensor and the ABS seemed to be fine.Dont think so but it came back on soon after leaving Ians and its been the same since.
It might be worth checking the wire from the speed sensor under the car... I seem to remember a slightly hurried application of self-amalgamating tape over the soldered joint as you were on your way to pick it up... maybe it's become damaged?You did... and then it broke itself again
Sounds like I caused your problem...Just a follow up on this, I fixed my abs problem thanks to lastminute.
That's interesting - and a little concerning...the heat shrink separating the two inner cables had worn through causing a short
IIRC it was because the replacement sensor we used had been cut off the donor car.I still can't quite fathom why it was fitted this way in preference to just plugging it in at both ends though.
