Hopefully someone can help....
I've taken apart the 722.4 transmission on my 95 e300 d as I suspected there was a B2 problem.
I found this instruction book:
http://avtopedia.ru/akpp/722-3 722-4.pdf
Now, on page 47, it refers to one way valves (item 49), but I can't see any one way valves at all in the transmission, or on the big plate that is sandwiched by the valve body. I think the book is referring to a 722.3 transmission here (p 47) so hopefully there aren't any equivalent valves on the 722.4 that can be removed at this stage (or fall out).
Does anyone know if there should be any little bits to look out for apart from the oil deflector (119) and temperature throttle (117) on the 722.4?
I'm worried that there was a valve and it might have fallen out when I removed the plate...
Any advice appreciated.
