Hi Nick,
I have recently changed the mounts in my E300D ('95, 217k). One was seriously shot, so I thought this might sort it. However, ever since, the engine appears to be resting on the body (or chassis? Not sure exactly where) when turning right on idle, or in reverse, resulting in a lot of rumble and vibration. The mounts were from GSF, and were the same part number for each side. I can move the engine by pushing/pulling it, which I would not really expect with new mounts (the engine in my 200TE is much firmer). I did notice that there was a small amount of oil which came out of one of the mounts if I inverted it as I was fitting, so is it likely that the fluid may have drained from one? There was no sign of fluid leakage on the item or the box when I removed it initially.
Have I bought the wrong items from GSF? They looked up by reg. no. so this should be correct for the chassis.
The engine does run a bit rough at idle (definite diesel clatter), and there are bubbles in the fuel pipes - (the O-rings is a job for warmer weather), but I want to sort these mounts first.
Many thanks,
Alex
