MB-tex
Yes, those parts for the subframe mounts are still (or were) made by MB. They were very expensive though back on 2017 when I bought them. Too expensive and I did haggle them down a bit but they are solid and just do the job. There are separate parts for the actual triangular mount and the lug plate that the subframe screws into. You'll see when you see a picture of them. The numbers are: 124 611 11 47 (Mount £63 each) ) 201 611 00 11 (Mount plate £34.70 each) But also there is a company in Germany 'Trabhan' that make peplacement panels for all the bits that rust out on these cars who are much cheaper. Haven't tried them yet but I will buy from them the panels for behind both headlamps for mine which need replacing. Below is their ebay page for the subframe mounts but on their main page are all the panels a w124 owner could possibly need. Bit more complex possibly buying from Germany now with new trading 'restrictions'. I am planning a trip to Berlin to see some friends in the summer (pandemic allowing) so will get the panels then.
Mercedes E-Class W124 Rear Axle recording + Thread Plate Axle Console | eBay
Pressing that axle/hub into the knuckle is tough. I luckily had a friendly local merc guy who let me use some of his tools. But even with the correct tool I was amazed at how tight it was. As a non engineer I am always impressed with those kind of narrow tolerances. Like I said before, make sure you have the brake shields in place before pressing them in!! Sounds like you did a good job on the rust under there. I did a similar job but much less effective than yours as I was on someone else's ramp so was in a rush. There is no stopping the rust - we can only slow it down!
Tom
Tom
