Car starts up great. Drives normally until engine is hot. Then becomes hesitant on acceleration. The hesitation quickly worsens over about 5 to 10 minutes. The car will then stall when accelerating from idle. It can be restarted and will idle rough with the car shaking. At this time, if put into Drive it will stall. If I leave the car idling in Park, the rough idle/shaking will suddenly disappear after about 20-40 minutes of idling. It will then run normally for the rest of the day. A few days later, the problem reoccurs again. It has been following this pattern now for many weeks.
Car is a 1991 W124-026, M103 engine. No change after replacing the spark plugs.
I was thinking it may be a moisture related problem because of the way it always recovers after idling for a while. Maybe something is wet, then dries up and resumes working. But I cannot find any water on the electronics. Anyone recognise the symptoms?
