Martyn_n
I am having trouble with my '95 E320, I tried staring it for the first time in a few weeks (Battery was fully charged first) and whilst it turns over fast enough it makes no effort to fire.
I have spent many hours trying to get to the bottom of it but have drawn a blank as to the root cause.
I have checked the incoming voltage to the ECU from the two outputs of the OVP and they switch on correctly so I think I can rule the OVP out (It's quite new) (I believe the third switched output is used by the ABS only)
The wiring loom is in good condition.
The ECU does not try to run the fuel pumps, I've checked and the ECU outputs a constant 8v to the relay. The pumps run if you bypass or false feed the relay.
All the injectors and coil packs have the positive sitting on them, just nothing from the ECU.
Does anyone know if the ECU checks the health of sensors before priming the fuel system by energising the fuel pump relay or does it do this immediately upon the ECU waking? If it does a health check I need to check the various sensors but I fear that it looks as though the ECU has died for some reason.
I have spent the last few weeks working in and around the front suspension which has involved me messing around with the brake pipes under the bonnet but I cannot see that I have disturbed anything that could cause me to brick the ECU. I'm gutted as I've spent a small fortune on welding and suspension parts and when I put it all back together this happens!!
Any advice would be appreciated.
