- Jun 18, 2010
- Location
- Sussex and Tuscany
- 2003 W209 CLK, 2005 R171 SLK, Volvo XC40 P8 Twin Motor Pro EV
1995 E280 S124 now at 132,000. This car has recurrent problems with a misfire. I have been through the old paperwork from the previous owner and I have had the car for just under 1 year. The story so far:
April 2007 at 107,000 Ignition coil x1
December 2007 at 116,000 Ignition coil x1. Repairs to wiring loom
September 2008 at 118,000 New wiring loom, Ignition coil x2, new plugs
Jan 2010 at 124,000 ignition coil x1 + HT lead
June 2010 at 128,000 Misfire but cured itself after 45 mins
August 2010 at 129,000 Misfire cured itself after 2 hours
November 2010 at 130,000 HT lead, plug cap and new plugs
January 2011 at 131,000 Ignition coil x1
All the above were to try and cure a misfire and seemed to work for a short time. All parts genuine MB. It is now back with the dealer again for the same problem. The guy working on it has 40 years MB experience so ought to understand the 124. I am now getting rather disheartened. The car is immaculate with no rust so I really dont want to give up. It seems as if we are treating symptoms rather than cause and that there is probably something causing all this to happen. Could it be the ECU? Any other ideas. All suggestions gratefully received
Nigel
Nigel
