mattc
Hi all
Nats 1993 e280 has just failed MOT on the following.
exhaust emissions carbon monoxide content after 2nd fast idle excessive.
exhuast emissions Lambda reading after 2nd fast idle outside specified limits
oh, and he did not like the front indicator bulbs (thought they were a bit dim) - so new bulbs for them.
here's the test data
fast idle test
CO max 0.2 actual 1.492
HC max 200 actual 151
Lambda min 0.97 max 1.03 actual 0.967
second idle test
CO 0.2 actual 0.534
HC max 200 actual 91
Lambda min 0.970 max 1.03 actual 0.995
Natural idle tst
CO max 0.300 actual 0.290
The car has only be on local journeys round Brum for a few months now - no motorway speeds at all. Like an idiot I did not take it for a long high speed run beforehand which I have heard can "blow out" the gases. But is there something specifically I should be looking to change? As far as I can tell the Cat and Lambda sensor are original (nothing in the extensive service file to indicate it has been changed either).
I think the exhaust MIGHT be leaking so can this be part of the problem?
Thoughts please before I simply start swapping parts.
I should also add as I am moving home by the end of next week the estate is being rpressed into ferrying duties so not really able to leave it with a garage whilst they diagnose the cause.
matt
fast idle test
second idle test
CO 0.2 actual 0.534
Natural idle tst
matt
