Windy124
- Sep 26, 2014
- W124 320E Sportline
Has anyone got a pair of these by chance? Would prefer the ones with the electric contacts if poss
Thanks!
Thanks!
WDB124066 said:Tricky to fit those - helps if you get new star grip washers.
bing said:Plenty on eBay just search W124 visor clips
WDB124066 said:Grit teeth! Yes they do.
WDB124066 said:No mate, Try a screw driver that you don't want anymore or a steel spike and then grit your teeth
WDB124066 said:Go easy on screwing the bracket back to the body, maybe it won't crack again if you just nip it up. With the aid of a suitable grade of Locktite type material it shouldn't undo....
