W163 aftermarket stereo wiring question
fadge
I'm currently preparing to install a JVC KW-NX700 double din navigation system to my ML270cdi (W163), with a KS-BTA200 bluetooth unit and a KT-DB1000 DAB tuner.
I need some help locating the speed signal, is it in the iso connector that I removed from the original AUDIO 10.(Pin 1 I think?)
Also is there any place I can pick up a reverse gear signal other than running a cable to the rear light cluster?
Thank in advance.
