GeoffWestWales
Hi, Just bought a 51 plate ML 270 CDI, a couple of problems have reared there head, the hassle is the central locking will not work, if you lock the drivers door with the ignition key it only locks the drivers door.
I have had a look at the main fusebox under the bonnet all the fuses are all ok, so what would you suggest I start to look next?, any help would be great.
The 2nd thing I need to do is adjust the handbrake, I have not had her on the ramps yet so it may be straight forward, but any tips would be great.
Thanks in advance for any replies
