gsr121
Hi all, my first post and I am looking for help if anyone would be so kind...
I have a 2007 A Class Elegance SE and have an SRS fault which I have read as passenger seat connection error. Have had a look under the seat and am trying to understand which cable connects to the occupancy sensor.
I have attached a wiring diagram as I see it along with a picture of the yellow connector.
If it is the wire with the yellow connector that goes into the middle of the underside of the seat, how do I disconnect it for cleaning? I can’t work out how to unclip it.
If it is the wire that goes up the back of the seat behind the plastic back panel, how easy it is to remove the plastic panel.
If anyone has any experience they could share on finding and rectifying this fault , I would be very grateful. I would prefer not to fit an emulator.
Thanks in advance.
G.
Thanks in advance.
G.
