W202 Bottom ball joint replacement
Laters
N/W Lancashire
Honda CR-V
I had a weird feeling/noise appear on my c class (w202) when on or near full lock. It had been doing it since I bought the car but had got worse in the last few weeks :( . No noise over pot holes though :confused: .
I decided to check for any play anywhere and couldn't feel a lot but there was a little.
Got 2 new lower ball joints and fitted them today. Apart from having to take the disks and brake calipers off (so I could slacken the backplates and get enough room to remove/refit the ball joints :rolleyes: ) all went quite smoothly :) .
One of the locating pins decided to stick in the upright :( but that was easy to fix as the locating pin in the new ball joint pulled out without much force (and was exactly the same size) so I refitted the new ball joint leaving the pin in the upright :) .
The old ball joints were very loose and quite badly worn :( .
I guess they were the originals and the car has 74,000 miles.
After putting it back together it doesn't wander at speed and the weird feeling has stopped :) . Strange thing is I hadn't really noticed it wandering until it doesn't anymore. Its a lot nicer to drive at speed :D .
All in all not to bad to do apart from the nut that you cant get to on the ball joint :confused: and the only tool I had to fit it was a big open ended spanner :o .
One thing I did notice was the front brake disks are corroding badly :( (from the outside inward) on the back side (hidden by the backplate) so they are next on the list to be changed (next week) after I have checked the back discs for the same problem.
I suppose it doesn't get used enough during the summer when the weather is ok & I use the quantum. Next year I must remember to drive the merc a few miles every week.
Got both sides done within 3 to 4 hours and the cost of the ball joints etc was a lot cheaper than the last car I had to put ball joints on (honda aerodeck) & the job was a lot easier to do on the merc:D
and you got more than the normal 60,000 miles out of them!
