gaz.thomas
Hi all,
I tried to start my 2000 'w plate' w202 c240 this morning and it let me down. The remote central locking was working, the lights and horn were also fine but when I turned the key to start the car the starter motor clicked (sounded noisier than just the solenoid - I'm assuming it's engaging the bendix) but the engine wouldn't turn over.
I'm a fairly recent convert to the mercedes marque and I thought that, what with all the complicated electronics, the immobiliser may have confused itself, so I disconnected the battery negative lead and went back inside for a cup of coffee.
It looks like a gust of wind shut the boot lid for me and, as I'm sure you've guessed, the mechanical key has thus far refused to let me back into the boot (although it works on the door).
From searching here I'm fairly sure I can use the under-bonnet positive terminal to attach another battery to open the boot but I was wondering if anyone had any ideas as to what may be causing the start problem?
I realise that these cars are a bit fussy about the level of charge in the battery so I'll probably pick one up this evening (assuming public transport can get me home before the shops shut!) but is there anything else I should be looking at first?
Thanks,
Gaz
Thanks,
Gaz
