So I changed all the flexible fuel pipes on the car about 2 weeks ago, and hey presto, its been starting great (apart from the drain on the battery, but thats a different problem )
Today, however, it was a night mare to start. Flattened the battery that was in it, and almost flattened a fully charged spare one before it finally started
Any ideas on why its been fine and suddenly its not?
One idea I had was that the fuel line with the banjo on the end had a little green o ring that had been chewed up last time somebody had changed them. I replaced it with a standard black o ring of exactly the same size. Maybe its green for a reason?
All flexible fuel lines have been changed, apart from the one behind the shut off valve, because I couldn't get it off due to a rounded bolt, but like I said earlier, its been fine for 2 weeks
