W202 not upshifting and then not allowing reverse selection
Daffodi
Hi All,
Looking at buying an X' reg c220 auto W202 which only has one fault.
Once drive is initially selected it won't up shift, stays in first.
When you give up it then won't let you push the lever any higher than neutral ie, you can't select reverse, unless you turn the engine off!
Having just read another thread it sounds like I have a gear selector module issue to fix??
I'm going to take it too a garage and have the transmission fluid level checked first
Many thanks in advance for your thought.
Oh, also, can anyone recommend a good independent in North Norfolk (UK)?
