W203 270 Cdi Engine Knock
Wee T
Northern Ireland
2002 C270 Cdi
I have searched and read a lot of threads but can't seem to find my problem.I have a 2002 C270 Cdi estate.It has covered a genuine 81k miles.Yesterday whilst towing a car on a transporter around 1800kgs all in my engine started to knock.it sounds like it's coming from the top end but I can't quite pin point it.It sounds heavier than the usual sticky tappet on a small engined petrol car wich i'm well used to working on.Oil level is ok according to the dash but I added 1/2 a litre to see if it made any difference but it hasn't.Anyone got any ideas ? I hope it's not an expensive one to repair.
Could it be an injector knock?
Second that. A quick star test may shed some light on it
A star test is done on the diagnostic computer used in the mercedes dealers
Sorry, but if you towing 1,800kgs with a C270 then you are over the manufacturer's max permissible towing weight limit of 1,500kgs......you could get into trouble because of that
Trouble
Yeah i'm pushing it a bit but i'm always careful when towing and stick to 50mph.My transporter is under a year old and has excellent brakes.The Police around here don't bother you when your towing providing your being sensible and the set up looks safe.
