Hello guys, David newbie writing from Italy.
I'm having some troubles with my 2003 C200CDI 90Kw
the car has 165.000kms and I just had EGR valve replaced.
This is the problem:
In some cases (especially after a ride at constant 2.000/2.500rpm) when I try to speed up (reaching abou 3.000rpm in 5 or 6 speed), the car goes on limp mode.
I've been to Mercedes dealers,they connected the car to Star diagnosis system and the result was "Turbo charger overpressure".
They said the problem is wastegate which doesn't work properly and tried to lubricate it (with no results).
They also said that if I keep having this problem, the only solution will the the whole turbocharger replacement, as wastegate is integrated.
The car runs perfectly and has a normal oil consumption, I wouldn't like to replace the turbo for a minor issue like that.
Do someone has any suggestion or possible solution?
Thank you in advance
David
David
