Your Vin number will include a gearbox code. From memory the first three numbers are engine then its gearbox - poss 722 or something of that sort.
There is a thread on how to understand VINs I think.
Out of interest - how do you know you need a new gearbox? Could it be something simple?
Good luck
Thanks for that, Ill have a look when I get home, but is there a certain type/model that is fitted to every 270 cdi?
Forgot to mention that mine is an auto, so can I take the gearbox from any w203 c270 cdi auto an it should fit mine?
also, Im aware that the 270 cdi engine is used on other models also, would gearboxes form them fit into a c-class?
Sorry bout all the Q's! I know more bout VW/Audi/BMW and this is my first Merc so im still learning!
Well the problems from the gearbox are many! Firstly, it doesnt engage in any gear, a merc specialist had a look at the fault codes and there were quite a few (I think approx 20), so im just preparing myself for the worst case scenario! They are still looking further into the problem, so it could be something smaller but Ill update when I know more.
So far all they've mentioned is that theres no drive in any of the gears, and that theres some sort of slipping thats been occuring in some of the gears,similar to what 'clutch slip' would feel like on a manual motor so im told.
Ive had a read around the forums and it seems the electronic plate in the gearbox is pretty common, but with that at least you still have some drive in a gear, so this problem sounds worse than that!
