I've got a C270 CDI, with an annoying heater problem. The air con system works fine and the heater is fine when the engine's warm. The problem is that when the engine is cold, even with the temperature control wound right up to max, it still blows freezing cold air at you. With the winter coming up, this is going to cause me earache every time my other half drives it. I've tried the soft reset using info found on another thread.
Any other ideas please?
