W203 Heater problem
Aux heaters are the webasto type under the offside front wing when fitted and are diesel. Sweden uses 230volt block heaters.
If the air distribution on the 203 is out of sinc,re set it
203
To reset heater flaps and actuators
Switch on ignition.
Press recirculated air and defrost buttons on control panel together for longer than 5 seconds.
The LED's in the defrost and recirculated air buttons flash alternately.
Wait until the LED's stop flashing (approx 30 sec) system set to defrost LED on.
Switch off ignition.
After 40 sec re start engine.
Thanks for this Malcolm, been wondering what was wrong with my air flow in the cabin for a week or so and this has just sorted it right out.
Owe you a pint for that!
Hello!
I have a W203 Sportcoupe C220 cdi from 2003 and my heater booster ( electric heater) is broken. I went to a tester and the error P1664- heater booster circuit open, came up and it can't be deleted.
Can anyone tell me where this Heater Booster is located so i could take this part off my car and see if it can be fixed or if I need to buy a new one.
A picture or a code for it would be very helpful because I searched the Internet for two days now and I can't find anything useful.
I would go to a Mercedes Service but it's located 150 miles away from where I live and I can reach it only on weekends when it's closed.
Thank you very much!
hello mihnea, and welcome. the heater booster on your car is probably mounted on the engine block just above the starter motor. they fail very often and are probably unrepairable - but hey, i never tried! why do you want it fixed may i ask?
Block heater
Иллюстрация: 100 Узел: COOLING WATER PRE-HEATER
№КодЗаменаК-воВар-тНазваниеИнформацияПримечания032 A20315000542031500154 - HEATING ELEMENT 032 A20315001540001591504 - HEATING ELEMENT *006032 0001591504 001 HEATING ELEMENT 035 6111590480 001 GASKET HEATER ELEMENT ON CRANKCASE 038 000000001146 004 SCREW HEATER ELEMENT ON CRANKCASE M 6X16 038 910143006001 004 SCREW HEATER ELEMENT ON CRANKCASE 041 6012000096 001 PREHEATER
*006 FIRST EXHAUST STOCK OF OLD PARTS UP TO ENGINE 962 40 11603
Webasto jobby, this is what i fitted to mine, but was the petrol version.
Excellent, get in start car, fans on instant warmth and if car is frozen defrosts pretty damn quick, one day when i can be bothered i will wire it up to the internal fan so it defrost car for me like my pevios one did.
Think sit in the warm watching all your neighbours/workmates scraping the ice off their car then get in and try to drive off as the screen keeps refreezing!
Модель=203216 Каталог=69J Система: 50 RADIATOR
Иллюстрация: 330 Узел: INDEPENDENT HEATING
№КодЗаменаК-воВар-тНазваниеИнформацияПримечания010 2095000498 001 L HEATING UNIT ----- 0139902901 003 COMBINATION BOLT HEATER UNIT TO BRACKET 020 2035060140 001 BRACKET HEATER UNIT 030 2034920001 001 EXHAUST PIPE AT HEATER 040 0054910801 001 MUFFLER INDEPENDENT HEATING 050 2034920014 001 END PIECE INDEPENDENT HEATING ----- 1299950120 001 CLAMP FOR STATIONARY HEATER FUEL LINE 060 0049976890 004 CLAMP 24-26/16MM 070 1294921702 001 FRONT EXHAUST PIPE MUFFLER ----- 000000000543 001 SCREW STATIONARY HEATER LINE CLIP 6,3X19 080 2035060034 001 HOSE AT HEATER 090 2109971390 001 CLAMP 26-29MM 140 910143006001 004 L SCREW HEATER TO FRONT END ELEMENT M6X16 160 2035842238 001 L GUMMED LABEL INDEPENDENT HEATING 175 2038350064 001 RECIRCULATING PUMP 175 2038350164 001 RECIRCULATING PUMP 180 2035060560 001 PIPE HOSE TO CHECK VALVE 185 0079972090 001 L CLAMP 22/12MM 190 2035062135 002 HOSE LINE TO COMPENSATING TANK, WATER PUMP AND HEATER UNIT 195 2309950105 001 L CLAMP 34.5-41.5MM 195 000000000668 006 L CLAMP LINE TO COMPENSATING TANK, WATER PUMP AND HEATER UNIT 25-40MM 197 0069974290 001 L CLAMP WATER PUMP 28-35MM 200 2035062235 001 HOSE CHECK VALVE TO HEATER UNIT ----- 1403280688 001 DAMPING STRIP LINE CLIP FUEL LINE FOR STATIONARY HEATER ----- 0019954365 003 CLAMP STATIONARY HEATER LINE CLIP ----- 2039950022 001 CLAMP STATIONARY HEATER LINE CLIP ----- 0039900251 001 NUT STATIONARY HEATER LINE CLIP 210 1409950605 002 L CLAMP MOLDED HOSE TO HEATER UNIT 26-29.2MM 290 2034760801 001 LINE FROM FUEL TANK TO PUMP 300 2034766526 001 FUEL HOSE FROM TANK TO PUMP 300 2034766526 001 FUEL HOSE FROM FUEL-OIL PUMP TO HEATER 310 0059978890 002 CLAMP 320 0004707694 001 L AUXILIARY PUMP INDEPENDENT HEATING 330 2035060040 001 L BRACKET 335 2034762326 001 L HOSE ADDITIONAL PUMP 340 2034762426 001 L HOSE ADDITIONAL PUMP 345 0059978890 002 L CLAMP HOSE TO FUEL PUMP 350 2104780012 001 L RUBBER MOUNTING FUEL FEED PUMP TO CROSSMEMBER 360 2104780112 001 L RUBBER MOUNTING FUEL FEED PUMP TO CROSSMEMBER 370 0079970890 002 CLAMP HOSE TO FUEL PUMP 380 2034767726 001 FUEL HOSE FROM PUMP TO HEATER UNIT 385 2034760901 001 LINE FROM FUEL-OIL PUMP TO HEATER 390 0039900251 002 NUT FUEL FEED PUMP TO REAR FLOOR ASSY. 400 2038301996 001 HOSE 450 2038200997 001 TRANSMITTER INDEPENDENT HEATING 460 000000000995 002 BATTERY IEC 86-MN 21 470 2038201097 001 RECEIVER INDEPENDENT HEATING 500 2035402107 001 CABLE HARNESS FUEL-OIL PUMP 550 2035409608 001 L CABLE HARNESS STATIONARY HEATER-TELESTART SPLITTER 550 2035409608 001 L CABLE HARNESS 550 2035404009 001 L CABLE HARNESS STAT. HTR.-TELESTART FOR MOB. CTEL 600 0049979890 001 TIE STRAP WIRING HARNESS TO CLUTCH 3.4 X 375 MM 605 0059976090 001 TIE STRAP WIRING HARNESS TO BUMPER 3.6 X 150MM 610 2038321094 001 HOSE BETWEEN RECIRCULATING PUMP AND ENGINE 610 2038321294 001 HOSE BETWEEN RECIRCULATING PUMP AND ENGINE 670 0059970190 001 CLAMP HOSE TO RECIRCULATING PUMP 14-24MM
When I bought my W203 I didnt know it had an instant heater. I was gobsmacked when I turned on my car the first cold morning and got heat before I even had reversed out the drive.
A wonderful device and I would now HATE to go without one.
Hello again!
Thanks guys for the information! I want to fixed it because winter is coming and I want the engine to warm up more quickly and automatically to warm the cabin more faster. And to be sincerely i don't like the engine sound at all when it's cold. I found the part, the preheater kit, and it's around 400 pounds.
I will try to repair if it is an electrical fault if not I will replaced. But the hard part is to remove and I didn't found any tutorial on this.
lynall
Sa the post reply form you with drawings, i have just bought a T70 with T80 remote, when i messure the signal from pin 2 (grey wire) at the T70 there is 12V but it cannot power a relay ore start the heater, and when pressing both buttons on the remote i dont get any feed back, any idea ?
