Hello - I'm new to the forum and trying to figure out whether it is worth saving my trusty and much loved 2003 Kompressor
Long story short I parked near the river near Richmond and came back to find water in my car. I limped home, let the car dry out, replaced a couple of fuses and everything seemed to work as normal. I didn't realise at the time that there are significant SRS components under the seat. Unfortunately when I took the car in for an MOT there were multiple errors recorded including:
B2D95 Restraint system ECU-N2/7 Faulty
B2DB7 Restraint system ECU-N2/7 Faulty
B101D Window Airbag ignition squib - R12/22 Ignition circuit shorted to battery
B101B Side airbag ignition squib - R12/42 ignition circuit shortage to battery vo
B101F Window airbag ignition squib-R12/23 ignition circuit shorted to battery
B10B0 Driver airbag ignition squib-1R12/13 ignition circuit shorted to ground
B10B1 Driver airbag ignition squib-1R12/13 ignition circuit shorted to ground
B100D Driver emergency tensioning retractor (ETR) ignition squib
R12/1 ignition circuit shorted to battery voltage
I've taken it to my local mechanic who said he couldn't estimate how long it would take to sort through the errors - he suggested I try to talk to a Mercedes mechanic. I took the codes to the Mercedes dealership but they weren't interested in having a look unless I was ready to pay to have the codes sorted through (which he suggested was probably not worth it given their labor rates).
I'm a bit flummoxed as to what to do now and I need to either get it back on the road or find a way to sell / dispose of it :-( My question is whether these error codes mean anything to those on this board and whether they give a feel for whether or not it is worth chasing down a potential fix or essentially a candidate for the scrapyard only. I'd love to keep the car going if possible but don't want to spend more than it is worth.
Would very much appreciate any/all advice. Thank you!
