Evening all,
Wondering if you have any advice.
For a few months now I've been battling with the CEL, throwing up code P0171 Powertrain - System too lean.
A local mechanic friend thought it may be the MAS but I know from reading forums etc, it's most likely a split breather pipe, regularly getting a large hissing sound under the airbox after a long run on a hot day confirmed this in my mind. I've not had the time to get it checked as of yet, due to money and no real problems with the car.
I had the Timing Chain + Gears replaced in April, and the car is currently 1800 over service (as oil changed in Apr, 6k ago).
The car is a Petrol C180 Kompressor W203 M271 2005 Model with 78k on the clock with full Stealership Service History. Given the cars age, I don't think it's worth continuing that and Kwikfit up the road will do a Full Service for £169.
The car is also starting to misfire now in Cylinders 1 & 2 when the engine is hot and in idle, the Spark Plugs have not been changed since '09 (Prev. owner didn't really look after it at all it seems, NOTHING done in a service since a Full in 09, only minors since) and I'm thinking the spark plugs will be on their very last legs, causing the misfire in idle with the engine too lean.
So my question really is, am I correct in thinking;
P0171 is probably a breather pipe
Misfire is probably old and worn SPs as a result of P0171
And can you advise on;
Recommendations on Kwikfit Full Service (Including spark plugs, all filters except fuel) (Inde is still about £60 more expensive)
Would you guys recommend BG44K to give the entire engine and fuel system a clean?
And would it also be worth asking to replace the fuel filter in the service?
Money is tight unfortunately, hence the delay in all of this. I love the car but it's just feeling really deflated and lethargic currently and i'm hoping to renew it a little.
Thanks guys, really appriciate it. Sorry for not being so petrol headed, but have never really had the experience with cars!
