W203 won't start
So the alarm can’t be disarmed by pressing the remote unlock button and putting the key fob into the ignition doesn’t stop / disarm the alarm then the only thing you can try now is to unplugging the alarm siren.
You able to view the utube video ok?
Dec
Yes carnt disarm alarm will try disconnecting it yes I could view video thanks if alarm is disconnected should the remote locking then work ?
Normally, the remote locking will work even if the siren is disconnected.
I’m guessing the alarm siren is faulty and is in some way interfering with the unlocking/ locking, also when the alarm is sounding, putting the key in ignition should disarm the alarm, that doesn’t seem to be happening in your case, so, unplugging the siren might or might not solve the problem.
The alarm siren contains the brains of the alarm system, it’s not just a horn.
See… Alarm / Siren Issues : Goes off for no reason/Kills Battery FIX DIY.. - MBWorld.org Forums
Dec
Ok disconnected alarm makes no difference still the same
Let us know the cause of the fault when you eventually find a solution.
Dec
Did you ever find the solution to this problem ? I have the identical problem now.
