W204 2012 7spd Autobox
B4oxx
C300h Premium Plus AMG Sport
I've noticed this evening that if I tap the gearshift to the left whilst the gearbox is in 'Drive' the dash display changes from just 'D' to D and the current gear number, ie D3.
Is this normal?
Apart from altering the gearbox setting to S or M I can't find a way to revert back to just D.
Push gearstick left to change down as you discovered, right to change up.
To get back to D hold it to the right for a second or two.
If in D you hold it left for a second or two it'll drop to the most responsive gear... grest for overtaking :)
If you aren't familiar with the 7g auto box, you should read the appropriate section in the driver's manual to understand its features and quirks.
Thanks, perhaps I will read the book. Thought the gearshift would be the straightforward part of the book!!
Yep, it caught me out early on- coming from manual boxes, I had a habit of resting my hand on the lever- didn't noticed I'd tapped it left and restricted the gear range, had me worried when it didn't change beyond 3rd.
There's also a bit in the book on restricting the ranges for tackling steep inclines, might be handy one day.
