W204 7g-tronic limp mode
Wicksee
C250 coupe 2011
Hi all,
2011 C250 CDI 7g-tronic, facelift.
Driving on the motorway yesterday at 70mph. Put my foot down, no acceleration.
Tried kickdown. No gear change, no acceleration.
Selected Sport mode. No gear change, no acceleration.
Selected Manual mode. Tried flipping up and down gears. No gear change, no acceleration. Gearbox would not shift out of 6th gear.
As i was putting my foot down, the engine speed would surge from 2-3000rpm. Still, no acceleration. I assume the engine was spinning the torque converter, but the power was not being transmitted through the gearbox, thus TC was slipping massively.
Even in 6th, i would still expect *some* acceleration, and no TC slip.
I found a safe place to stop, cut the engine, and restarted. It was fine after that.
Any ideas what just happened? I have a 3 month warranty and I only bought it 2 weeks ago. Should I take it back and get the codes read?
I plugged in my own ODBC reader and no fault codes were found.
Many thanks in advance.
problems
? turbo actuator not moving. I had similar symptoms on my E280 the turbo atuator needed rebuilding.
Just wondering, :dk: why when you've already reached 70mph you might put your foot down? :p ;)
Is it a natural reaction when you feel there may be something wrong with your vehicle to attempt to further accelerate? :dk:
Btw, my posts couldn't have been more tongue in cheek if it tried.
I would suggest a check for error codes, then go from there.
