I purchased my Mercedes C220 W204 last year and I notice the car goes into limp mode (no EML) when I am on the motorway, this usually happens when I am trying to pick up speed uphill or when I am going from a 50 mph to 70 mph zone. When it goes into the limp mode the car will jerk and then stay in high revs and will change gears very late.
The fault codes are:
P2112 - Throttle body jammed closed, actuator blocked
P0248 - The output for the low pressure turbo charges has a malfunction. The actuator does not close.
I took the car to an Mercedes independent and they changed the Throttle body, but the fault still occurs on the motorway.
I've looked back at the cars history and the previous owner had the EGR Air pump solenoid, Turbo boost pressure solenoid, Vacuum pipe repaired and water pump/v belts changed 8 months ago (roughly 4,000 miles ago). This was all done by a Mercedes specialist.
Any ideas what this fault could be and what needs changing?
