royaltiger
- Sep 10, 2010
- W204 C220CDI Sport
Hi all
I have retrofitted a 2nd hand Comand NTG4 (replacing audio 20) and the problem I have is when I plug in the power harness for the monitor it blows fuse number 11 in the sam box, the Comand will work although I have only switched the radio on and sound does come through the speakers, the confusing part is why does this fuse keep blowing, if I leave the power chord in and replace the fuse it instantly blows, pull the power out and I can replace the fuse no problem, plug power back in and fuse has blown, This is the 2nd Comand I am now installing as I was having the same problems with the first Comand and a diagnosis seemed to point to a faulty Comand. So I am now wondering has lightning struck twice and this head unit is also faulty although as with first unit the radio works ok, or there is something I have got wrong in the setup, I checked the wiring and that seems to match every other install, it should all work as its a case of just plugging in the extra loom but something is not right, has anyone else had this problem and found the solution, pulling hair out as cannot understand whats wrong. The Comand is from Lithuania but should not make a difference either as its a european model
