Plitty84
Good evening I have a 2013 W204 CDI with currently has intermittent engine light on and lack of power no kick down etc. Fault Codes:
P2279-06
P0299-00
P2279-62
I’ve had the intake system checked for leaks etc which garage reported as ok, they recommended to replace the EGR valve due to possible internal air leak which didn’t cure the fault.
Now they are recommending to replace the map sensors which may have conflicting information causing the fault. Problem is I thought there is only one map sensor? If there is two are they located close together?
Any help/advice is greatly appreciated, many thanks Andy
P2279-06
P0299-00
P2279-62
