Hi guys
I've been looking at getting a second hand C class estate (W204 model) but I'm a little bamboozled with all the changes to the engine line-up Mercedes have made since it was first introduced.
I would appreciate anyone's input of with an overview of the different engines and the relevant changes (and when they were introduced).
From my own research, I have found out the following:
Petrol
Initially a kompressor/supercharged engine, changed to a turbo later on (I beliebe when CGI came out). CGI fuel injection system also uses uprated piezo injectors.
The facelift model has increased efficiency/power output (i.e. 1.6 engine used in c180/1.8 for 250) - not sure what the engine changes were to enable this?
Mercedes also added the eco stop/start to the blueefficiency range.
Diesel
In particular, the v6 320 cdi became the 350 cdi - but later on the output increased massively a particulate filter was added. When were these changes and what did Mercedes add to increase the power output.
I would be grateful if anyone can help by giving me an overview of the changes and when they happened, etc.
Also - wanted to know - do Merc still use the piezo injectors after all of the recalls in the c200/220/250 models when first released? And have all the issues been ironed out?
Thanks in advance.
Petrol
Diesel
Thanks in advance.
