w204, retrofit , facelift
lancer
london
2011 cdi 250 sport
hey guys ,
dose anybody know if the w204 facelift amg sport rear bumper fits on the pre facelift 2010 model like wise with the front bumper, i heard the bottom of the front headlights are the same shape, so the sport pack bumpers should fit can anybody confirm this :dk:
The facelift rear bumper does fit as far as I am aware I am just in process of having one fitted as I am just doing the C63 styling to my 2009 C250 cdi sport and liked the look of the facelift rear bumper so I have bought one from the guys at germancarspares.com and know just to get the front bumper and side skirts off eBay then it will be going to the body shop for fitting
ah cool i like the face lift rear bumper too it looks much better , i hear the front fits with slight ajustment on the front lights
Did you carry on with the facelift parts around the front? Sorry to bring up an old thread!
Hi there , im doing the c63 conversion also with quad pipes ,how are you going about with the exhaust and getting it welded
Hi iam new on here need help with a facelift steering wheel on a pre w204, ive put a 2012 c63 steering wheel but the functions, horn and paddles are not working.
Take if off.
It fits but the buttons (including button lights) and everything you mentioned won't work, they might work if you replace the electrical board and wiring from the pre-facelift steering wheel into the facelift wheel (behind the airbag)... Unless of course it might just need the steering column to match your new wheel
More is explained in this thread~ http://mbworld.org/forums/c-class-w204/541142-diy-fl-steering-wheel-swap.html
It isn't plug and play
thanks for that, ive also read something about having the wheel recoded is that possable?
You've probably got a MY2013 or later wheel. The MY2012 wheel (which is facelift) works, but the 2013 onwards electronics all changes
If you've got the part number of what you put on, I can check
Richard
[edit] please also note that i'm not sure whether the lighting will work, but the one we've done the horn/paddles/buttons worked
richard said:
You've probably got a MY2013 or later wheel. The MY2012 wheel (which is facelift) works, but the 2013 onwards electronics all changes If you've got the part number of what you put on, I can check Richard
Shouldn't have told us that! I want one now...
most probably it is a 2013 but ill ave to take it apart and get the number, let say it is is there a possability of having it recoded u reakon ?
Hi Richard just found out the steering wheel is of a 2013
So on that note you reakon it can be adapted by recoding it?
Which part numbers fit a 2008 C63 AMG to upgrade to the facelift one?
