mtayre
Hello all,
I'm back again with yet another issue with my car, they seem to be endless at the moment. Basically the car is cutting out when warm and won't start up again for a few minutes, it then continues to do this making it impossible to go anywhere. Must apologise for the essay but just wanted to be detailed with what has happened.
The problem first showed on Saturday, had a couple of mile run and switched off for five minutes whilst in a shop, came back out to start the car and it failed to start properly first time, fired and seemed to be starting but as if it was only working on one cylinder and eventually cut after about 3 seconds. Turned the key again and started no problem but the engine management light was on. Car drove fine, no problems at all.
Later in the day started the car up, no engine management light and the car was working fine. I went out of town, about 20 miles away no problems at all. Parked up for an hour came back started up and everything was fine. Drove no more than a mile and then the engine cut out completely, all lights came on the dash, but no malfunction warnings in computer. Tried to restart and nothing, did not even attempt to turn over, no starter motor click nothing as if the immobiliser had kicked in. After about five minutes, started up again without any warnings at all. Drove another 500 yards and then ABS/ESP/BAS failure messages all popped up. Managed to limp the car back home with all these on and other than the obvious things that wouldn't work it was fine.
Started it up on Sunday to see if the faults were still there and all was fine again. Went for a small run to get it up to temperature to see if I could reproduce the fault and sure enough, as soon as it hit normal running temperature it cut out again. On attempt to restart nothing at all, no starter motor click or turn over.
So far I’ve had the battery tested, no faults and checked the Crank Position Sensor no faults. I can’t get into the garage until tomorrow, to see if there’s any errors stored so does anyone have any other things that I should look out for? I'm really stuck this week without the car.
Cheers
Michael
Cheers
Michael
