w208 clk Need to remove front head lamp-how?
aka$h
London
Anything with a 3 Pointed Star!
I need to take the head lamp on the drivers side off, how can i do this?
You help would be very much appriciated,
Cheers
moving to bodywork . . . you may get a better response there.
S.
Come guys, someone must know how to do this.
I need to access the front wing to push out a dent, but im not sure if i need to remove the wing in order to do this?
usually on most cars you have to remove the front bumper as the head lamps are bolted on to shacey so to gain access you remove front bumper then bolts should be straight under head lamp. hope this helps
If you PM me with your email address I have a Word document with pictures that explains exactly how to remove the headlights - I prepared it when I replaced my standard lights with Xenons.
Not too difficult but some of the mounting points are hard to find.
If you want the document let me know
Guy
Cheers
This is the Benz method for Xenon removal.
