W208 clk55 low fuel lamp
astamir
london
w208 silver clk55
Hi guys
Bought my first AMG recently it's 2000 w208 clk55 the low fuel lamp is not working on the dashboard just wondering if I can replace a bulb or do I need to change the cluster
Thanks in advance and wish you all the best
So no one had this problem before? And no one can suggest anything?
These guts only reply when they want to i have posted so mNy times one major issue but no help!!!
Just a thought...
maybe no one who has looked so far can answer the question?
You've had answers to all of your questions , barring the ridiculous ones.
If you don't like it here , take your attitude and find another forum.
This forum is good in it mate used always to get the advice and suggestions
Take the cluster out of the dash, change the bulb. Refit the cluster.
If you need diagrams on cluster removal you will need to join MBO and look up Television he will pm them to you. This board is for leasing quotes and left wing drama :)
There are also videos on youtube.
Not sure on your particular model but on on models that I am familiar with there are two senders, one for the light and one for the guage.
I would start with the bulb though in the first instance.
From looking over the OP's previous threads and those of the other antagonist here it would also probably help in eliciting accurate responses if we did not need to guess, most of the time, what the question being asked is?:wallbash:
when you switch the ignition on stage 1 do all the bulbs light up? inc the low fuel one? if so then its prob the fuel sender unit, if it doesnt light up then it could be a simple bulb gone.
Slightly OT but I had a similar thing happen in my house.
About 6 months after moving in one of the bulbs in the ceiling blinked out.
I called the estate agent I'd bought it from & they advised me to buy a new house, which seemed a bit OTT. Doing some research on my own I discovered I could get away with buying just the ceiling. Saved a lot of hassle & money!
Hi no the light isn't coming on when u switch the ignition
Any links would much appreciated)
