steveoelliott
- Mar 8, 2013
- CLK 230K W208
Hi Folks,
On my 2000, CLK Cab, my drivers side window stopped working. I took it to an ex Mercedes Mechanic who has the STAR machine and he diagnosed the issue with the door control module. I sourced a new part direct from Mercedes which has been fitted and coded to the car, however, the guy I took it to said he had some issues getting it to talk to the roof control module (suspects it faulty).
As a result, whilst the window works in fashion, it doesn't work correctly. In order for it to go down, I have to half press the button down and for it to go up, I have to fully press the button up. What is very strange is when the window is part down, if I do opt to press the switch fully down, the window goes up! Clearly something isn't right. It seems that fully down makes the window want to go up!
Just wondered if anybody has seen this behavior before.
Interestingly, I have also noticed when operating the hood that as part of the close procedure, the rear headrests raise, this never happened before.
Thanks...
Thanks...
