RodgerDodger
I am planning to refurbish the beasts suspension - items on the agenda are listed below (order placed today with dealer for parts in bold)
Please note: although some part numbers given below maybe common accross the W210 range, I have noted that some parts (in partucular the springs and shocks) are rated dependant on cars specification/trim/options etc. - this is the main reason I have sourced the bold parts direct from the dealer and discounted other sources.
Springs
Do i need rubber shims for the top of the springs - car is an ********** on 98K
Ditto - the aluminium anti-corrosion rings at the bottom - not sure if they come with the springs
Do anyone have set on spring compressors i could borrow - near central Scotland
ARB link and bushes - will research the forum for the links / howto's - any major bananna skins worth mentioning?
Engine Mounts - Ditto ARB above
Brake Disks - bit of a dilema here - should i go OEM or upgrade??
Brake Pads - ditto disks - thinking out loud...the pads and discs should be packaged together - is this correct - or should i mix and match (cant get pick'n mix now ) - Any advice or general comments very welcome
Tools and Equipment
Any advice on small/specialst tools needed (particularly for the above items) would be appreciated.
Also, are there any special MB Spec or better fluids/llubricants worth investing-in - for above and general future maintenance?
Tks
R
- FRONT SPRINGS - £58.65 inc vat each. - Pn. A2103212104
- REAR SPRINGS - £60.95 inc vat each – Pn. A2103243404
- FRONT SHOCK ABSORBERS - £100.63 inc vat each
- REAR SHOCK ABSORBERS - £108.68 inc vat each
- FRONT ANTI ROLL BAR BUSHES-£5.29 inc vat each - Pn. A2103231585 x 2
- FRONT ANTI ROLL BAR LINKS - £8.34 inc vat each - Pns. A2103203789 & A2103203789 (L/R? tbc)
- ENGINE MOUNTS-£79.35 inc vat each - Pns.A2032400617 (L) & A2022403017 (R)
- FRONT PADS - £59.85 inc vat
- FRONT DISCS - £60.95 inc vat each - Pn. A210 421 2212 x 2
- REAR PADS - £47.66 inc vat
- REAR DISCS - £41.63 inc vat each - Pn. A210 423 0612 x 2
- REAR SUBFRAME FRONT MOUNTS - £59.23 inc vat each
- REAR SUBFRAME REAR MOUNTS - £45.54 inc vat each
Springs
Tools and Equipment
Tks
R
