w211 e class wont crank
tuc2904
Belfast
Mercedes e270
parked car fri night left over night and went to head out sat afternoon, when i tried to start car i got nothing.....not even a click or hint of starter trying to turn over engine...... checked battery voltage 13volts using meter and straight onto terms.... then discovered you can call it up on cluster display where i got 11.8volts then dropped to 10.4volts when key turned to pos 2.... took battery out and as i speak still on charge.... was reading else where about shecking fuse box in engine f54... which is a 20amp and fine however f59 which is also 20amp is blown and wondering if that is the fuse for the trigger to starter and if so may well be where my prob lays or does the car think its not in park or neutral..:dk:. anyway any help on this would be really appreciated... oh anyone know where i can get fuse box maps for this car.... 2003 e270 cdi....... thanks for taking the time to read this and offer suggestions....
