- Feb 8, 2007
- Location
- Portsmouth, Hampshire.
- E55K SL500 E250X2 Smart44 Brabus Track car E450Cabriolet X350 Pick up
We had a 2006 C Class have glycol contamination. Its not just some Valeo rads that do it.
OK, not sure if anyone is watching but I'll keep updating as it may be useful for others.![]()
pmcgsmurf said:She lives again. :bannana: Fitted propshaft today (decided to get new flexible joints), filled box , ran a little and brought the box up to 80 degrees to get level right. No leaks, running ok, so seems fine again, not had proper chance to road test yet but looking good thus far. Did get a brake or parking brake error so guess I've got some sticky pads or similar to look at but that's another day. Dropped a spanner under the air filter so had to remove that and lost a few clips, it was rather dirty under there. Total repair cost so far £559 inc. Torque Converter but obviously excluding the labour cost.
Sometimes the valve in the valve body that controls the lock up clutch wears. This may cause accelerated wear of the new TC too if the lock up in the TC has failed. It's not common but I have seen it a few times.
Showing codes:
2200 The signal from component Y3/8n2 (Internal speed sensor (VGS)) is not available
2225-1 Transmission control ETC FAULT 8
