Back again with further questions.
I bought the actuator motor for the intake port shutoff (MA642 150 04 94) D5-01 Servomotor and three ball socket clips (MA642 091 01 50) D6-03B.
Two questions.
1) If I replace the servomotor myself do I need to remove the air intake manifold i'e' split it and replace the gasket or can I just undo the old servomotor (three bolts and electrical connection) and just bolt on the new servomotor once I've cleared everything out of the way?
(If I do have to split the air intake manifold I might as well clean up the swirl flaps and replace the plastic 'rods' for the better aluminium/metal set up)
2) How important is it to program and code the control unit re manual data transfer after replacing the servomotor?
Two questions.
