Brake pads warning has been on for months. Inspected brake pads when it first appeared and there was at least 5-6mm left (looked at the outer side only) so assumed faulty sensor. Inspected yesterday still at least 4mm left on the outer side. The inner side looks like almost completely warn out.
It looks like original pads including sensor, bolts, some other staff can be bought from a dealer on Ebay at a good price:
The questions I have:
1. Do I need to disable anything electronically as seen some horror comments on the internet about pumps getting activated even with ignition fully off (i.e. key out)?
2. Do I have to open a bleeder valve to ensure the fluid from the piston does not flow to parts of the system where any debris might cause damage? If so is there a risk of introducing air into the system/how to deal with it?
3. If I could get both wheels off the ground it would make the job very easy but I have just a poor quality jack that came with the car and some old axle stands. So will be doing one side at a time. Can I turn the front wheels to the maximum before jacking (to maximally expose the caliper)? Will it be safe to jack the car with wheels turned to the maximum? Will I be actually able to get the wheel off when it is turned to the maximum?
Genuine Mercedes-Benz W211 E-Class FRONT Brake Pads and Sensor A0004207104 NEW | eBay
Suitable for most W211 E-Classes Excluding AMG Line models. 100% Genuine Parts. Brakes Components. Can't find what you are looking for?. Isle of White. Isle of man.
www.ebay.co.uk
