Good stuff , I can’t believe that your engine mounts don’t need doing at 140k thoughHaving had the rear mount changed the vibration in reverse when cold has reduced significantly but is still there.
According to my Indiependent, the rear mount was had not failed but was showing signs of degrading. I am sure it is not gearbox related as changes are smooth and selection of Drive or Reverse is instant with no noise or clunks. I can only assume that the remaining symptoms point to the need for the front mounts to be replaced.
Incidentally, whilst he was checking the car he found 3 large splits in the Right-hand intercooler charge hose. The car had been suffering a very occasional loss of power which always reset after cycling the ignition with an occasional "Low boost pressure" code stored. I am very surprised that it was able to generate any boost considering the size of the 3 splits.
Having had it replaced the car is now quieter and more responsive plus the charge hose was only £55 from MB.
I agree, they have not failed but will have certainly deteriorated and they are supporting a big lump up front as my dearly beloved might describe meGood stuff , I can’t believe that your engine mounts don’t need doing at 140k though
My recent change of my mounts at 107k transformed the car and the way power is deliveredI agree, they have not failed but will have deteriorated and they are supporting a big lump upfront as my dearly beloved might describe me![]()
Did you have the Propshaft couplings changed as well?My recent change of my mounts at 107k transformed the car and the way power is delivered![]()
I didn’t , my Indy said that’s not really something they ever change on our model carDid you have the Propshaft couplings changed as well?
Don’t bother changing them David unless there’s visible cracking on the rubberDid you have the Propshaft couplings changed as well?
Just for youIHow about a picture of the beast? I miss my e320 cdi.
The W211 is such an elegant designJust for you![]()
That happened to me a couple of times with them too, I won’t buy from them. They list an OEM part for a very cheap price and bump the price of their own brand “Stark”. When you contact them, the response is along the lines of “we sent a more expensive part, you got a great deal”I've just replaced the engine and transmission mounts on my cls with om642 engine. It's cured the vibration and feels like a different car now.
But beware buying from autodoc, I ordered febi bilstein mounts but recieved "stark" mounts. From a quick search on the internet it's not the first time they've replaced orders with thier own parts. I fitted them anyway but it remains to be seen how long they will last.
That’s is one nice looking w211Just for you![]()
Ditto!That’s is one nice looking w211
