W211 e55 amg airmatic
kopkid
w211 e55 amg
Airmatic not raising red warning message on dash'stop-car too low' front passenger side slightly lower than other corners
Thanks for sharing...
Can you hear the compressor running?
Couple of possibilities -
Knackered compressor
Kanckered airmatic unit or units
Knackered air reservoir
You need to go and see a good specialist who will put it on star and do a leak test on the suspension
I've ended up replacing the front units, having the reservoirs welded and replacing the compressor!
How many miles has the car done out of interest??
Kopkid - have you ever been to North Weald for the Run What Ya Brung event?
get it on star kopkid, unless its an obvious leak!, could just be the compressor as its not dropped, star will tell.
just make sure you go to someone who can read the Star codes properly. The MB dealer in Edinburgh got the fault code wrong!
Car has done 146.000 throughly maintained was just going shopping when warning came up at Epping,, cannot hear anything running
Is the reservoir in the boot right hand side??
Nice one thanks,, car does not sink overnight only slightly on front passenger left
